LT1/LT4 Tech 1993-1997
throttle body
Old Oct 22, 2006 | 06:36 PM
carguylt1's Avatar
Default throttle body
I'm rebuilding the topend of my 95Z. I already have the LT4 hot cam kit, 2.02/1.60 valves. I plan on port and polishing the intake and heads, midlength headers, fuel pressure regulator, accel ignition system. I have to replace the injectors what size do I need? I also found a 58mm throttle body for $200 would that be to much?
Old Oct 22, 2006 | 06:56 PM
carguylt1's Avatar
Default RE: throttle body
The 2.02/1.60 valves will fit wont they?
Old Oct 23, 2006 | 02:08 AM
The valves will fit but you will need new seats. The $200 for the throttle body isn't bad, but you could put that money to better use. The stock valve can handle up to 400HP.
Old Oct 23, 2006 | 04:10 PM
carguylt1's Avatar
What size injectors would be good?
Old Oct 25, 2006 | 09:57 PM
The stock injectors should handle the extra power, but make sure the PCM is reprogrammed to take your mods in consideration, otherwise you will be wasting your time.
B_Dubya
Sep 23, 2014 11:01 AM
z28?SS?
LS Series Tech
Feb 10, 2011 10:49 PM
sebi1990
Feb 6, 2011 08:00 PM
Skippysnax
Nov 10, 2008 04:53 PM
Skip94z28
82-92 V8 Tech
Nov 21, 2006 03:47 PM
