Throttle Body
Old Feb 6, 2011 | 03:33 PM
sebi1990's Avatar
Default Throttle Body
How to you remove the net thats before the throttle body?
Old Feb 6, 2011 | 03:40 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
You mean the thing covering the MAF?
Old Feb 6, 2011 | 05:05 PM
any fish in it? lol must be the maf like socom is sayin. leave it alone. you can clean it if your carfull. maf is very sensitive, doesnt take much to mess em up and they are not cheap. check shbox and see if theres a how to on there.
Old Feb 6, 2011 | 06:13 PM
sebi1990's Avatar
Ok I've cleaned it but is there a way to take it off?
Old Feb 6, 2011 | 06:43 PM
Massey's Avatar
no there is not. And dont remove it if you want your car to run right. That screen helps create a wind tunnel and force directed air across the MAF sensor. This gives the MAF a cleaner reading. Without that screen the air would be turbulant and random and could cause dead zones around the sensor, giving readings of less air than what is actually going through (leaner mix) or more air (richer mix). Either way you are losing optimum burn, and timing as well.
So leave that alone just make sure it is good and clean.
Massey
Old Feb 6, 2011 | 06:49 PM
sebi1990's Avatar
ok i just wanted to clean the throttle body and the sensor but ok.
Old Feb 6, 2011 | 07:41 PM
use maf cleaner only, dont use starting fluid or carb cleaner and try not to spay on the elements. let dry completly before re installing.
Old Feb 6, 2011 | 08:00 PM
sebi1990's Avatar
yeah that's what i use but when i can't take off the net i can't get in there and wipe in i'll take of the whole throttle body and do it cuz my car shakes a bit and so did my moms ford explorer...after i cleaned it with the maf cleaner it dose not shake and runs very smoothly.
B_Dubya
Sep 23, 2014 11:01 AM
z28?SS?
LS Series Tech
Feb 10, 2011 10:49 PM
Skippysnax
Nov 10, 2008 04:53 PM
Skip94z28
82-92 V8 Tech
Nov 21, 2006 03:47 PM
carguylt1
Oct 25, 2006 09:57 PM
