LT1/LT4 Tech 1993-1997
? to those with 4L60's
Old Aug 5, 2011 | 02:05 PM
torque_is_good's Avatar
Default ? to those with 4L60's
will your car also start in neutral or only in park?
It's one of those things that I never really paid attention to and the 95 will start in both.
Since I drive manny tranny's as my daily drivers the gear doesn't matter, I just need to throw in the clutch
thanks
now I wonder how many had to read this, go outside and find out for themselves???
Old Aug 5, 2011 | 02:31 PM
BasicConcepts's Avatar
Technical User
all auto transmissions will start in park and neutral... the only reason i can think of is if your cruising down the rd and for some reason your car stalls you can put it in neutral instead of pulling over???
Old Aug 5, 2011 | 03:25 PM
Yep, ever hear of a "neutral safety switch" before? The switch disables the starter if the trans isn't in park or neutral. And yes, the neutral position is for instances like what B.C. stated.
Old Aug 5, 2011 | 03:32 PM
or if the linkage is adjusted wrong. i would think it would be a safety feature, you dont want to be starting in gear.
Old Aug 5, 2011 | 06:19 PM
yup, i've heard of a neutral safety switch. That's what i get for driving manny trannys. As i said, i never paid attention to starting in neutral. Any auto tranny car I've worked on i just keep it in park.
thanks guys
Kwacasey
11
Jul 28, 2010 07:36 PM
SixShooterCamaro
Jul 30, 2009 09:38 PM
Adamloveshis99camaro
Apr 14, 2008 09:19 PM
Goodfella
Nov 18, 2006 01:29 AM
