LT1/LT4 Tech 1993-1997
THERMOSTATS 160 or 180?
Old Mar 7, 2006 | 08:57 PM
user 7208220's Avatar
Banned
Default THERMOSTATS 160 or 180?
Title says it all...whats the difference? and also what are the best brand of headers for a decent amount of money...decent i mean 400-500 maximum.
Old Mar 8, 2006 | 09:36 PM
Default RE: THERMOSTATS 160 or 180?
All that means is that the 160 stat will open at 160, and the 180 will open at 180. This does not mean that the engine will run at that temperature, as the PCM will have to be updated to turn on the fans at the proper temperature to go with the stat you are using. Theorethically, running the engine at a cooler temp should give a few extra horses, but what really makes a difference is the temperature of the air being sucked into the engine.
As for headers, go on the web and hunt around, but basically you are going to get what you are paying for. I suggest going for a known name brand with some sort of warranty against warping, and rusting or burning out.
superROB23
Oct 2, 2007 06:28 AM
claytoncoombs2002
Feb 28, 2007 12:21 PM
