LT1/LT4 Tech 1993-1997
TDC indicator mark ?
Old Aug 24, 2010 | 09:15 PM
osduck5's Avatar
Default TDC indicator mark ?
What exactly am I looking for as a marker? Is it an arrow or some type mark on the harmonic balancer? I have turned the harmonic balancer over several times today but don't find any marking. I had the heads off and I turned the crank so the number one piston was all the way up in the cylinder but still could not locate a mark.
Old Aug 24, 2010 | 09:25 PM
If you have an LT1, there is no marker, and if it is stock, no marker is needed. Why are you looking for one?
Old Aug 24, 2010 | 09:35 PM
osduck5's Avatar
It is a 94 LT1 and reading the Haynes manual, it was saying the marker should be at the 12 o'clock position on the compression stroke for true TDC to adjust certain rockers and then rotate the crank one complete revolution to adjust the rest of them. I have found a couple things that puzzle me with that manual, like it is showing to put RTV around the water ports on the intake for a LT1. ???
but to answer your question, I just replaced the head gaskets and need to adjust the rockers tomorrow.
Old Aug 25, 2010 | 12:20 AM
there should be an arrow on the front of the balancer that is set to the up position when the motor is at tdc on #1 piston. it really dosent matter because the front balancer dosent do anything so it can be set in any position. and litterally can being there is no key to limit it. front of a lt1 is internally balanced and the rear is not. see the arrow or triangle in the picture
http://www.gmhightechperformance.com.../photo_13.html
Old Aug 25, 2010 | 10:00 AM
osduck5's Avatar
Thanks craby for the pic. I was looking on the outside of the pulley and not on the front of it.
Old Aug 25, 2010 | 10:25 AM
That static two-step adjustment is fine for getting the engine running initially, as long as you are going to readjust the valves the "engine running" way. As a "set & run" adjustment, it sucks. If you want to do a static adjustment only, follow this procedure: http://www.chevyhiperformance.com/te...nfo/index.html
Old Aug 25, 2010 | 11:39 AM
yah he had the heads off so he has to get em close first. duck,,,glad i could help.
Old Aug 25, 2010 | 09:18 PM
osduck5's Avatar
Thanks Camaro 69. I adjusted them today. Finished installing the intake, wiring, etc. Need to get the exhaust manifolds back on and it should be ready to fire over but I think I am going to double check the lash setting first since today was my first attempt. Also, I think I am going to turn the crank a few times with a socket and ratchet just to make sure everything seems good before putting the battery to it. I hate second guessing myself!!!
86CamaroZ28
Jun 12, 2010 05:29 PM
robdog
82-92 V8 Tech
Jul 11, 2009 07:58 AM
1995CamaroZ28
Jan 16, 2009 09:18 PM
95ZDropTop
Apr 20, 2008 07:35 PM
vampyrico
Mar 31, 2007 05:48 PM
