Tach wiring
Tachometer
white or red/black
ac
coil/dist. assembly
Notes: White-V6, red/black-V8. Location is front of left cylinder head for V6 and at a 4 pin plug at the passenger side valve cover for the V8.this should help u out the tach sense wire should be tapped into this. then of course your power and ground need to be hooked up.
