LT1/LT4 Tech 1993-1997
T-56/ 10 bolt issues
Old Feb 18, 2011 | 12:13 AM
x01660's Avatar
The Mustang Hunter
Question T-56/ 10 bolt issues
Ok, this is whats going on:
1995 Z28 M6
When shifting from 1-2 under partial throttle, there is a clunk and a jolt that sounds like its coming from the differential.
I feel the shifter lever moving under acceleration. It just starting doing this.
Also, when doing a clutch dump or fast acceleration, the tires skip instead of spin.
I am brand new to standard trannies, so it might be something simple. Please help me keep my Tremec alive!!
Thanks in advance.
x01660
Old Feb 18, 2011 | 12:57 AM
Sure sounds like your transmission mount is torn. The torque arm from the rearend is attached to the tail of the trans. With a torn mount, the torque will lift the rear of the trans and let it bang the tunnel. Your shifter moving or lifting is another side effect.
Old Feb 18, 2011 | 01:01 AM
x01660's Avatar
The Mustang Hunter
Ok, so how expensive are mounts, how difficult are they to replace and how long can I drive the car before I have to change them. I have to make a 670 mile round trip road trip tomorrow...... Thanks.
x01660
Old Feb 18, 2011 | 09:34 AM
You can drive with the mount torn, just go real real easy on the right foot so you don't go lifting the tranny. Changing the mount is fairly easy, two bolts on the trans and one on the crossmember. But you need to jack up and brace the car (with stands) so you can get under it. And jack up on the tail of the trans to clear it for getting the mount off and back on.
MBlac649
Jun 17, 2013 05:51 PM
Kopack2007
Jan 28, 2011 08:12 AM
MS69 YENKO/4-SPEED
Jun 22, 2010 05:07 PM
gozzy341
Nov 4, 2007 08:52 PM
gotalcoholmanup
Oct 13, 2006 01:41 PM
