Suspension and brake questions
So I've got some questions about upgrading my suspension, and i want to know specifics about some things:
What benefits will I see from upgrading (over stock):
Panhard bar
Torque arm
relocating LCA's
And what is a good set of shocks for the car. I am not concerned about ride quality (as in smooth) I want maximum road feel.
Now, about the brakes: Can I get rotors from an LS1 F body and use them without any modifications? What can I do to my brakes (short of upgrading to C5 brakes) to maximize my stopping and minimize brake fade under strenuous conditions?
Thanks, fellas.
x01660
Panhard bar
Torque arm
relocating LCA's
Thanks, fellas.
x01660
quality shocks n struts will give you the most. i would say sway bars next. have you looked at what strano has? i switched to the cross bar mounted torque bar to keep from busting trans mounts. with each of the parts you mentioned you will feel a small improvement.
x01660
