LT1/LT4 Tech 1993-1997
superchargers and turbos
Old 03-26-2009, 04:54 PM
auSStin's Avatar
Originally Posted by ls1s13
ls1's and lt1' can handle nos pretty good idk about boost tho
not to be a ****, but its nitrous NOS is a brand of nitrous accessories. My LS1 runs strong on the spray.
And LT1s and LS1s can be deadly as f*ck when boosted. Some mods are a smart idea to be safe. Its much more expensive though
Old 03-26-2009, 06:21 PM
SpecterGT260's Avatar
Ninja Administrator
a simple * doesnt change the fact that you are using language not allowed on the site. please watch that in the future.
Old 03-26-2009, 09:10 PM
whammer3024's Avatar
ROTM Winner
spend the money you were going to spend on a charger system and build your bottom end. go with a low compression forged 383. use quality parts...then save for your charger. at least then your motor will be able to run high HP numbers NA and be able to handle more boost when you slap it on there
Old 04-04-2009, 10:44 PM
carguylt1's Avatar
I like the idea of a little lag it helps getting off the line. If you put the turbo in the back you gain more power with the same boost. The air has a chance to cool a little before it is forced into the intake. The c5 vet makes an extra 50 horses just from putting the turbo out back. The plumbing would be a pain but for that much more power it makes since to me. You also have to upgrade the fuel system either way you go most provide you with upgrades and programmer unless you try to piece it together from scratch.
camaroowner
08-25-2011 10:50 AM
68chev350
10-01-2008 02:30 PM
98sleeper
03-09-2007 06:54 PM
iriswalsh04
11-02-2005 03:42 AM
Quick Reply: superchargers and turbos
