supercharger anyone??
anyone in here boosted? i'm thinking of building up my block and intake for a supercharger. increase my block compression a lil with just about 4-6 psi of boost. i'll pull the heads and check out my cylinder walls at the beginning of the year. just curious to see if anyone has done what i'm planning....
RE: supercharger anyone??
If you going to build for a supercharger, do it right to get the most out of it. Forged internals, trimetal bearings, hold compression below 8:1, beef up fuel delivery, blower grind cam, long tube headers, good aluminum heads with heavy deck to prevent cracks, free flow intake, intercooled supercharger pushing 15 to 20lb boost, water alchool injection to prevent detonation. Get computer tuned properly.
ORIGINAL: HURSTLT1
Get a rebuild with forged internals, and keep the compression ratio at around 8.3:1 and you'll be good to go. Then, you could safely go with about 10-12lbs of boost, and don't forget the intercooler.
thanks for the advice guys, i've actually been thinking gmcrate 383 all motor....just have the whole motor built, sent and i'll install it...have to drive to tampa or orlando and get it tuned though....just hard trying to find sites that sell gm crates.
