LT1/LT4 Tech 1993-1997
stuck revs
Old Sep 23, 2010 | 06:59 AM
imcdowel's Avatar
Default stuck revs
what would cause the revs to get stuck at around 2200 or 1500 rpm. if i rev it a tad it goes to normal idle. iac??? it does this pretty much all the time...
Old Sep 24, 2010 | 10:08 AM
sticky iac valve/motor
Old Sep 24, 2010 | 02:47 PM
imcdowel's Avatar
quick fix or replace it?
Old Sep 24, 2010 | 03:16 PM
take it out and have a look, if it looks like it needs a good cleaning try that. otherwise you may want to test it or just replace. they are easy to remove, i take the tb off to make it easy to get to it and the tb is not hard to take off.
Old Nov 25, 2010 | 01:45 PM
imcdowel's Avatar
i replaced the iac with a working used one (apparently) and i cleaned it. the problem hasnt changed at all. so what else would cause this or could the iac that in bought be bad?
Old Nov 25, 2010 | 04:58 PM
make sure the thottle is not sticking. cable, linkage, bent anything. or do you have thottle by wire.
Old Nov 27, 2010 | 12:43 PM
imcdowel's Avatar
throttle by wire. maybe i got a bad one. it didnt rev up like that for the first 80 miles or so... now its pretty bad...
Old Nov 27, 2010 | 01:14 PM
sure sounds like it. tps is the only other thing i can think of.
Blake_Camaro00
Apr 29, 2015 08:24 PM
mpr21290
Mar 7, 2015 01:23 PM
RonnieJ86
Dec 5, 2012 08:58 AM
4g63t
82-92 V6 Tech
Jun 3, 2011 02:30 PM
mgray
82-92 V8 Tech
May 12, 2007 11:46 AM
