LT1/LT4 Tech 1993-1997
stroker or lt4 swap
Old Jan 7, 2012 | 02:03 PM
dogdog130's Avatar
Default stroker or lt4 swap
i found a guy will do a 383 stroker installed for 2K what kind of camshaft would be good for a good lump sound but for the same price i can get a lt4 swap so should i do 383 first then do the lt4
Old Jan 7, 2012 | 08:07 PM
jrgearhead's Avatar
You will defiantly get more power out of a 383 then a lt4. For the money you can buy better performing aftermarket heads, cam and all that rather then the lt4 setup. http://elliottsportworks.com/ is a great place to checkout diffrent cam setups for what you want
Old Jan 7, 2012 | 08:16 PM
dogdog130's Avatar
i found a guy in my area known for his work he do it for 2K with my military 25% discount so i mite be doing that
Old Jan 8, 2012 | 01:32 AM
383 is the way to go, le2 heads from elliotts, 11.5 or 12 to 1 compression, intake by elliotts, cam from elliotts, longer stroke will need bigger cam. 1.6 rr, not going to be pushing much more hp than a lt1 with same mods but tq should be neck snapping. lt4 kit is not that good.
Old Jan 8, 2012 | 09:17 AM
dogdog130's Avatar
yea i want a cam in it that u can hear but nothing crazy
wasting rubber
Dec 11, 2012 09:19 PM
garb
Mar 3, 2010 02:26 PM
tray z-28
Nov 27, 2009 01:13 PM
1988camarov6
82-92 V6 Tech
Aug 14, 2008 04:45 PM
IROCU
Jul 20, 2007 02:07 AM
