LT1/LT4 Tech 1993-1997
need help 383 stroker
Old Feb 16, 2010 | 05:29 PM
garb's Avatar
Default need help 383 stroker
ok so after thinking and talking with my dad i decided to build a 383 stroker for my ss does anyone have a link to something that will help me build it the way it should be done as in right parts and what not cause i dont wanna spend a crap ton of money and not have it right
thanks for the help in advanced
Old Feb 16, 2010 | 07:03 PM
CraZ28's Avatar
Banned
I am doing the same. I just recieved my "How to rebild Small-Block Chevy LT-1/LT4 Engines". It has some very useful info as to recondition your block and prepare for the boring/cleaning/checking procedures. As well as all the hidden freeze plugs and the infamous "steel ball" located in one oil passage. Plus I found out my engine did not come with a needed gasket above the oil cooler mount from the factory.
But anyways, have you decided to go with 5.7in. rods and pistons or 6in. rods and pistons?
Old Feb 16, 2010 | 07:07 PM
z28rob18's Avatar
thats a good book. go 6". if you just take some time to read and research online you'll be good. is the shop putting the short block together?
Old Feb 16, 2010 | 07:08 PM
CraZ28's Avatar
Banned
I stayed with 5.7 rods myself. Wiseco pistons are pretty good, I guess, and they have K1 stroker cranks and rods available too.
Old Feb 16, 2010 | 07:13 PM
garb's Avatar
i was going to build it myself but i might have the local speed shop do it i just need to get the book and parts and i most likely will got with a 6.in rod
thanks for the info
Old Feb 16, 2010 | 08:20 PM
CraZ28's Avatar
Banned
Well I would not let anyone touch my motor, if you want something done right you have to do it yourself. I don't even trust the machine shop to bore and hone it right but I don't have the machine to do it.
Good luck......
Old Feb 16, 2010 | 08:30 PM
z28rob18's Avatar
well the machine shop may know alot more than he does about building a motor. and the 6" rod is a little less stress on the cylinder walls
Old Feb 16, 2010 | 08:43 PM
black95z28's Avatar
this guy makes me mad. not gunna name names, but i think people know who he is.
Old Feb 16, 2010 | 08:47 PM
whammer3024's Avatar
ROTM Winner
callies dragonslayer 3.75" crank
6" lunati rods
diamond pistons
LE2 heads and cam package
42# racetronix injectors
comp pro mag 1.6 rockers
whatever pushrods lloyd recommends
let a COMPETENT machine shop put it together for you. the bottom end is pretty much like a SBC to put together and lets face it, any good machine shop has done a million of those. you can slap on your own heads and install your own cam. that should be a pretty stout build if built correctly
Old Feb 16, 2010 | 08:53 PM
ROTM Winner
oh, and LOL!
