LT1/LT4 Tech 1993-1997
Still puzzled, car running too rich? moisture?
Old May 12, 2010 | 10:17 PM
Old May 13, 2010 | 08:25 PM
rwing7486's Avatar
Originally Posted by z28pete
Rich running does not produce a white vapor, rich running results in black smoke. What you are probably seeing is normal moisture in the exhaust system being blown out. The smell of burning gasoline is common until the cats light up, and until the PCM switches to closed loop, and follows the O2 sensors. The smell goes away as the cats get to running temp. If you are still concerned, get a scanner, not a plain code reader, and see what the PCM is seeing.
ok so ive determined that the SES light for the DTC 43 code goes away after the car reaches closed loop. Now like u said pete once the car is in closed loop in follows the O2 sensors. Before it reaches closed loop does it follow the knock sensor? and i did notice the SES flashed for like 1 second while in closed loop...believe it was the DTC 43 since i didnt reset the codes on my computer and a new code didnt show up. so u think its either the knock sensor or the module?? im going to test the resistance of the knock sensor this weekend
strokerracing
Jul 11, 2011 06:59 PM
gfrench
Sep 16, 2010 08:39 AM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
atlanta2008
67-69 V8 Tech
Sep 13, 2007 06:24 AM
chevyryder
May 17, 2007 02:08 AM
