LT1/LT4 Tech 1993-1997
starting problems
Old 11-02-2010, 09:32 PM
intmidator's Avatar
Sounds like a security issue or the key chip may be bad.
Old 11-02-2010, 09:52 PM
osduck5's Avatar
Is the bulb burned out on the security light or do you see it come on when you turn the key to the "run" position? Can you get it to crank over if you short the solenoid on the starter?
Old 11-03-2010, 08:02 AM
ladiesman2684's Avatar
the bulb is fine for the security light. it comes on and goes off like it is suppose to. it does start when you short the selenoid.
EasternStryker
02-28-2010 09:57 AM
videojunkie1986
06-03-2009 06:02 PM
justingarcia947
10-08-2008 12:25 AM
KrazyHobo
11-20-2007 07:48 PM
jdubs1813
11-08-2007 01:42 PM
Quick Reply: starting problems
