LT1/LT4 Tech 1993-1997
Starter motor removal.
Old Dec 5, 2008 | 02:25 PM
wowcow's Avatar
Default Starter motor removal.
I have a 97 Z28 which in the haynes manual it states you only need to remove the exhuast on 1998 onwards to remove the starter, unless I'm missing some magical way of physically making the starter motor thinner than the gap between downpipe and sump I assume you have to remove it on all V8's.
The rear end of the downpipe unbolted easily at the 2 bolt flangebut then it appears to go up in to a drum/cat looking silencer before bolting on to the drivers side manifold (header in the USA?).
So.. do I need to remove the exhaust? and if so it looks like 3 bolts holding the downpipe on to the header, is this correct or do I only need to undotwo (two look easy, one is tucked away at an angle and looks a real ***** to get to and I'm not entirely sure it's part of the downpipe, again haynes manual is useless at this point) or worse,is their more hidden somewhere?
Old Dec 5, 2008 | 02:30 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Starter motor removal.
try unhooking everything on it and look for a gap. i didnt have to remove my exhaust to get mine off on my 98..... its kinda tight, but you should find a hole somewhere. i usually trust haynes, if they didnt remove the exhaust i dont htink you should have to
Old Dec 5, 2008 | 03:12 PM
wowcow's Avatar
Was yours manual or Auto? I think if I didn't have what looks like auto trans cooling pipes I could get it out.. circled piccy below
http://www.digitalphotos.pwp.blueyon...sc/starter.jpg
Old Mar 16, 2009 | 01:46 AM
Robuilt's Avatar
i have a 6M and did not have to unbolt the exhaust. wiggle it out
Old Mar 16, 2009 | 08:36 PM
rondavis's Avatar
the lines look trans cooler lines they bend fairly easy just be careful and the starter should come right out i had no problem getting mine out i have m6 and it shouldn't be that hard
surfhppy
Sep 16, 2012 10:01 PM
sdmd88
Apr 23, 2011 09:44 AM
mccoyj91
Nov 28, 2010 07:55 PM
VanHalen
Oct 9, 2009 10:02 PM
CAMAROSKI
Jan 11, 2008 03:55 PM
