LT1/LT4 Tech 1993-1997
starter
Old Aug 25, 2012 | 09:16 PM
numskull223's Avatar
Default starter
Quick question, I have a mini starter and it drags when the engine is at running temp. I had the battery checked and its fine. So my.question is, can you rebuild it like ypu can a stock starter? And does that sound like a tired starter to yall?
Old Aug 25, 2012 | 09:30 PM
BasicConcepts's Avatar
Technical User
sounds more like its over heating, try a heat shield first and see if that helps.
Old Aug 25, 2012 | 09:52 PM
i use one on mine, its one of these Thermo-Tec 14150 - Thermo-Tec Starter Heat Shields - Overview - SummitRacing.com with this starter Powermaster 9502 - Powermaster XS Torque Starters - Overview - SummitRacing.com its been in for a year with no issues. first starter (tuff stuff) lasted 3 months without shield.
Old Aug 25, 2012 | 11:37 PM
Im using Powermaster 9600. With no shield. Been on since 2009. When my car is at 160* its a stuggle to restart it. Almost like an HEI engine when the timings off. LOL. Starter rebuild or heat shield?
http://www.summitracing.com/parts/PWM-9600/
Thats not a sign thats somethings wrong with these LT engines is it?
Old Aug 25, 2012 | 11:55 PM
nope the motors not hot. try the shield first, its usually the windings that go south so rebuild will probly not do much.
Old Aug 26, 2012 | 12:24 AM
What makes them start dragging when they get hot?
Old Aug 26, 2012 | 12:38 AM
It's not engine heat that's affecting the starter, it's exhaust heat.
Starter fine when cold, but not fine when hot...you have a heat issue.
You want to try and isolate the starter from the heat source.
Old Aug 26, 2012 | 02:17 AM
Yep, cold, it has no probs. I'll wrap it up.
RJ350
Sep 21, 2012 07:26 PM
iLL95
Oct 17, 2011 02:51 AM
VanHalen
Jan 6, 2010 09:02 PM
camarodrifter
Dec 29, 2006 08:08 PM
94Z28interceptor
Nov 14, 2006 08:09 PM
