LT1/LT4 Tech 1993-1997
spark plugs in my exhaust pipes??????
Old May 28, 2012 | 11:07 PM
I'm thinking maybe a po installed a 96-up exhaust, and plugged the extra unused 02 bungs with the spark plugs. Hey, they are "plugs".
Old May 28, 2012 | 11:10 PM
dang the truck i had had 3 so i figured it did to. i stand corrected. thanks. well it still should be thowin codes so ses light should be coming on. ive read that guys have used spark plugs to plug the bung holes. ouch
Old May 28, 2012 | 11:12 PM
BasicConcepts's Avatar
Technical User
ya i dont think id want a spark plug in my bung hole
NSFW
http://www.youtube.com/watch?v=pr7OCRfnjEw
damn i love the jerkey boys
Old May 28, 2012 | 11:15 PM
he should have the car scanned for trouble codes to see what comes up and yah,,, pre ignition could be explosive.
Old May 29, 2012 | 11:05 AM
dlaidoutranger's Avatar
i think that they might have just used whatever was laying around when they did the cat delete and just plugged the holes with whatever they had. im redoing the eshaust before too long, going to go from the bbk unequal length headers to some coated long tubes and run a x-pipe with dual bullet style flowmasters with turn downs before the axle, i just thought it was wierd cause i couldnt figure out what they had going on, the exhaust work was done before i got the car
Old May 29, 2012 | 11:15 AM
jkeaton's Avatar
How do you guys get away with deleting the cats? Here in NC, the car does not have a smog check if it's older than 1994, but it still has to pass a visual and all factory installed emission controls have to be present and installed (you could gut them and get away with it) or the car fails visual. Probably different state to state I guess. Or, you know someone who turns a blind eye to it??
Old May 29, 2012 | 01:16 PM
Technical User
in sc theres no emissions at all and in ny i had a buddy that hooked me up with "legal" emissions stickers. it was legal to my car but i never would have passed
Old May 29, 2012 | 02:00 PM
In IL, it's 1996 (OBDII) and newer that gets tested. No more sniffer tests.
Old May 30, 2012 | 06:23 PM
torque_is_good's Avatar
sniffer tests...........bung holes being plugged
I'm backing out of this thread
Old Jun 3, 2012 | 06:27 PM
  #20
Grandpaswagon's Avatar
Different states have different inspection requirements. Here in WA there are two different emission requirements depending on your location. In most of the heavily populated areas in the western part of the state and around Spokane, they have actual emission tests. For most of the eastern side of the state there are no emission tests at all.
However, all emisison controls are required at the federal level. There just is no federal testing requirements other than for cars fresh off the factory assembly line. If the EPA ever got a wild feather in their nether regions, they could enact a federal testing program and require both visual and sniffing tests on all vehicles that originally came with emission equipment. That would really put a lot of folks in a bind, and would lead to huge repair bills (or more business for the crushers) for most cars over ten years old.
