LT1/LT4 Tech 1993-1997
spark plugs
Old Mar 1, 2007 | 02:29 PM
tyler2497's Avatar
Default spark plugs
What spark plugs fit a 93 z28?
Projected or non-projected tip?
tapered or non-tapered seat?
5/8 or 13/16 hex?
what reach?
what heat do i use for best performance in a stock engine?
Old Mar 1, 2007 | 03:15 PM
shnormo's Avatar
Default RE: spark plugs
http://sparkplugs.com/results_app.as...p;AAIA=1035852
If you plan on owning your camaro for a long time, I recomend the Iridium plugs.
Old Mar 1, 2007 | 03:21 PM
tyler2497's Avatar
http://www.jegs.com/webapp/wcs/store...53645_-1_10391
i was looking at these but i dont know which ones to order
Old Mar 1, 2007 | 05:23 PM
Use the plugs shown on shnormo's post. The ones you are looking at are for modified engines, and if you don't pick the right ones, they won't work right, and may even cause damage. If you have doubts, go to a GM dealer and get a set of OEM plugs, they are good for 100K.
Old Mar 2, 2007 | 02:08 AM
tyler2497's Avatar
ok thanks
Old Mar 2, 2007 | 03:12 AM
aap94z's Avatar
oh yeah and find a double jointed pollock to change them for u
Old Mar 2, 2007 | 09:19 PM
camarorz28's Avatar
when changing plugs just take your time start in the hardes side which is the passanger side, then move on to the driver side , driver side pretty easy.
Old Mar 3, 2007 | 04:02 AM
95slvrZ28's Avatar
I find it's easiest to get plug #8(far back pass. side) out from underneath. Just a little tip.
VALHAR
Jul 22, 2013 02:14 PM
jeu510
67-69 V8 Tech
Oct 26, 2012 04:21 PM
Z28Freak
Apr 19, 2011 01:02 PM
sebi1990
Oct 10, 2010 10:24 PM
