LT1/LT4 Tech 1993-1997
spark plug HELP
Old Apr 21, 2010 | 07:14 PM
Stillborn's Avatar
Default spark plug HELP
Ok its my first time doing my plug and wires. Driver side was 1hr now the passager side I'm just lost. Got em all out now it just seems impossible to get em back in. Any pointers?
Old Apr 21, 2010 | 07:37 PM
whammer3024's Avatar
ROTM Winner
you gotta work at it bro...its not easy and i just did it this past saturday. took about 3 hours between customers coming in at the same time.
can you get them started with your fingers? that's the best advice i can give. you might need to get a socket that has an end where you can put a wrench on it since space is limited for a ratchet
Old Apr 21, 2010 | 07:59 PM
Stillborn's Avatar
My major problem is the first plug on the passanger side the header makes it just seem impossible.
Old Apr 22, 2010 | 01:11 AM
#2 is easy #8 is a three bandaid shot. some have taken the starter lose and moved it to get to that back plug from the bottom.
Old Apr 22, 2010 | 07:43 AM
joedirt's Avatar
Remove the Alternator , put some 30W oil on your arm to slide down that narrow passage....lay towels over the Radiator..and lay across towels and engine...lol....stick your arm in there...and work at it....I shattered that plug when I removed it....BUT I got it...remember the Anti Seize...
Old Apr 22, 2010 | 08:05 AM
ROTM Winner
i guess i don't remember having many problems with that one myself
Old Apr 22, 2010 | 09:13 AM
i dont know how all the headers are and i take it they are all shaped different, with the kooks the number 6 plug is the nightmare.
Old Apr 22, 2010 | 01:40 PM
Stillborn's Avatar
Well my pacesetters nearly make em all nightmares on the passanger side. I thought number 8 was easy lol its number 2 I can't get.
Old Apr 23, 2010 | 01:53 PM
Stillborn's Avatar
Ok so I got some help and we finished it this morning. Car sounds amazing.
Old Apr 23, 2010 | 06:07 PM
for the sake of the thread i will add that if u losen the header on the pass side, just enough so the bolts dont come out on ya, its much easier. on mine i also take the starter lose and move it outa the way to get the back two. just done mine in 4 hrs. best time yet.
