Sometimes starts and turns off but starts up when i try again
Sometimes (about 10%) when I go to start my car, it fires, the rpms go up and it cuts right back off. But when i go to crank it again, it starts fine. The past couple times it has done this, my exhaust 'pops' a couple times. Also, when i accelerate while the heater is running, it accelerates rough and shaky. Any ideas?
Yeah its the 96 LT1. No the ses isnt coming up. So im guessing i need to get fuel pressure gauge? I am also losing coolant. i have to add it about every month or so. I haven't been able to tell where it is coming from because its not dripping out. im guessing it must be hitting something hot and evaporating. This has been going on a little bit longer than the starting and cutting off issue though so its probably not coming from the same problem. but ive had the water pump and radiator replaced within the last year as well as the head gaskets.
drewski
02-10-2010 11:27 PM
