LT1/LT4 Tech 1993-1997
lt1 question
Old Dec 11, 2011 | 04:32 PM
skinut's Avatar
Default lt1 question
I finally killed the engine in my camaro last week. Spun a rod @160,000 miles. Looks like ive got some work ahead of me once again. Anyway I found a guy thats practially giving away a running lt1 with low miles out of a 94 or 95 roadmaster. Is this engine the same as 95 camaro or are there some differances.
Old Dec 11, 2011 | 04:45 PM
Catmaigne's Avatar
The heads will be iron and the PCM will be different
Old Dec 11, 2011 | 04:57 PM
skinut's Avatar
Ok i thought the heads were iron. Have heard they are better. Could i just swap all the junk from my motor over to this one and make this work? The guys letting it go for 250 bucks...
Old Dec 11, 2011 | 05:14 PM
iLL95's Avatar
I Like to Party
Super Member
If you have all the correct harnesses and electricals I dont see why not. Is he throwing in the PCM? While you're down there I would change the motor mounts
Old Dec 11, 2011 | 05:20 PM
skinut's Avatar
No pcm and yea the cars gonna get a few things. A fresh clutch being one of them. I dont see why shouldnt beable to make this work. Worse case I dont see why I could'nt just use the block and rotating assembly from the buick along with everthing i have.
Old Dec 11, 2011 | 05:32 PM
No, your aluminum heads are better. That's why the Camaro and Vette got them, swap them onto the new engine. And you're in luck that the engine is from a Buick. The F and Y body cars had the old style unvented opti through 1994, then got the new vented style in 95 (like yours). But the B body cars (Buick is one of them) got the updated opti in 94. So, that Buick LT1, even if it's a 94, should be sporting the same opti as you already have. Change the heads and the accessories from the old to new engine, and you should be set. No need for a different PCM.
Old Dec 11, 2011 | 05:41 PM
skinut's Avatar
Ok cool. That was my plan. Good news is i had my heads redone a few thousand miles ago. Other wise this sucks... Its getting cold out there.
Old Dec 11, 2011 | 08:48 PM
Catmaigne's Avatar
Get a space heater.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
