LT1/LT4 Tech 1993-1997
slap shift question on a4
Old Apr 27, 2011 | 06:53 AM
bobshannon22's Avatar
Default slap shift question on a4
ok, so i got a 95 z28, a4. stock tranny if it matters, but the (ef me what it called) place where the drive, overdrive, neutral ,rev, and park are, but i have 2nd,d,od,n,rev,and park, no 1st gear option. I noticed today that if i hold it all the way back, like after 2nd gear, that i also have a first gear too. is this bad for my tranny because i dont have a 1st gear option?
im sorry it sounds so confusing, just wondering if its bad for the car cause ut might help me with hitting rev limiter on 1-2 shift
Old Apr 27, 2011 | 07:42 AM
timmyz28's Avatar
No its not bad. I had the same exact thing. That means you have 2.73 final drive gear in the rear. All it is is a little rubber block under the middle console on the shifter. If you look at it, its a piece with the teeth in it to lock into each gear. I cut half of that block off so I had first as well. It won't do any harm, just don't do 60mph or so and slap it into 1st. It all comes down to common sense.
Old Apr 27, 2011 | 10:45 AM
ohh,, nice, i might trip that block then, thank you,, 2.73, is that the good gears then? didnt they come with 2 dif packages?
Old Apr 27, 2011 | 10:52 AM
check your rpo codes, should be in the glovebox or center consol. sticker with a bunch of numbers and letters. rearend is a gu and then a number. like gu2 is 273 and gu5 is 323
Old Apr 27, 2011 | 12:08 PM
timmyz28's Avatar
LT1s came with 2.73 for auto and 3.23 for 6sp. LS1s came with 3.23 for auto and 3.42 for 6sp. I'm not 100% about the LS1s though.
Old Apr 27, 2011 | 01:08 PM
nope, both my lt1 auto's had 323's
Old Apr 27, 2011 | 01:11 PM
timmyz28's Avatar
Really? Dang man, I wish I was that lucky lol
Chevra
Mar 28, 2012 10:07 PM
Roscoep
Sep 20, 2011 12:59 PM
Tom071
70-81 Transmission & Differential
Feb 24, 2011 10:27 AM
98ss4REAL
LS Series Tech
May 1, 2007 02:06 AM
CamaroSpeedRacer
Apr 23, 2007 12:07 AM
