LT1/LT4 Tech 1993-1997
383 Stroker
Old Apr 27, 2011 | 10:26 AM
NorthernCrew454's Avatar
Default 383 Stroker
I was looking at getting a 383 stroker kit from Bessel Motorsports - StrokerKits.com - The Home of the Build your own 383 Stroker Kits. Plus, Bessel Motorsports Blocks, Splayed Caps and Block Supports.
Anyone ever heard of them or know the correct part number for the lt1? i think i need the one seal rear correct? and the 5.7" rods or 6"?
thanks
Old Apr 27, 2011 | 12:19 PM
timmyz28's Avatar
That's cheap for a stroker kit, but you pay for what you get. That seems too good to be true. I've never heard of this company either. Honestly, if you want a strong, durable build, your better off buying all the parts you need and do the build yourself so you know exactly what parts your putting in your car.
Old Apr 27, 2011 | 12:20 PM
timmyz28's Avatar
And yes, it is a one piece rear main. Not sure what factors play a part for rod length. I think part of it is clearance in the pan.
Old Apr 27, 2011 | 02:35 PM
so i called up the company and he was saying he has customers running I beam rods at over 700 Hp and it doesnt pay to run the H beam, saying even top fuel run i beams?? sounds like a load of bulll
Old Apr 27, 2011 | 03:28 PM
if your going to stroke have a reputable shop do it. runs about 3k. your already 30 over so that should save a little.
italiafutbol07
Jan 6, 2011 06:31 PM
Sodamhot
Oct 3, 2009 10:05 AM
morphine51
70-81 V8 Tech
Feb 25, 2009 09:26 AM
buckfever
Dec 15, 2007 10:25 PM
travis t
Oct 29, 2007 07:48 AM
