LT1/LT4 Tech 1993-1997
Sealing the Opti??
Old Apr 3, 2009 | 02:14 PM
derekstl's Avatar
Default Sealing the Opti??
So i am putting in a new optispark (distributor) because my water pump leaked on it and fried it. I know this is a common problem because the water pump is mounted directly around it. SO i was wondering.... When I put the new one on, do you think i could seal the optispark so no moisture gets in?
Wanted to check before i did it.
Thanks,
Derek
Old Apr 4, 2009 | 12:51 PM
luckyhdnox's Avatar
I have a 93 z and it came with a non vented optispark. I bought the vented and used rtv blue to seal it. I had my upper radiator hose blow and it poured every last drop of hot coolant on the opti and it still works to this day. I should point out that three other hoses have busted since. If you don't have new hoses and can afford to get them, please do.
Old Apr 4, 2009 | 03:22 PM
I did the same thing to my car several years ago, just for grins & giggles. I don't know if has helped any, but definitely has not caused any problems.
Old Apr 4, 2009 | 03:37 PM
Optiburner's Avatar
I did the same thing last year....i've had it out in the rain and so on and have had no issues since. Knock on wood
Sophm
Aug 3, 2013 11:00 PM
shai one
Feb 27, 2012 10:48 PM
NorthernCrew454
Sep 4, 2011 07:42 PM
jeff2285
Feb 7, 2010 03:33 PM
jeff2285
Feb 7, 2010 01:34 PM
