LT1/LT4 Tech 1993-1997
running hot
Old Jun 16, 2010 | 09:35 AM
ladiesman2684's Avatar
Default running hot
This may seem like a stupid question but my 96z is running hotter than it should. what is the normal operating temp for it? The fan doesn't kick on until about 225 degrees. This seems a little high to me. I'm trying to figure out if this would be a problem when i switch to aluminum heads.
Old Jun 16, 2010 | 11:00 AM
What your engine and fan is doing is normal. You can do different things (computer tune, different sensor) to make the fan turn on at a lower temperature. And your LT1 engine already has aluminum heads.
Old Jun 16, 2010 | 11:33 AM
is that something that i can get at any auto store?
Old Jun 16, 2010 | 08:41 PM
have you checked the coolant level in the radiator, when cold of coarse. it may help to bleed the system to see if you can get some air out. so it is running hotter than it was before? how long have you had the car? you can have a tune done at pcmforless and get some better performance at the same time.
chevyguyjay
May 13, 2010 09:33 PM
Foxracing254
Oct 1, 2009 11:32 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
1badroc
Jan 24, 2005 02:55 PM
