Roller rocker polylocks
I'm doing the adjustments to my Scorpion 1.6RR and some of the polylocks tighten down a lot further down into the hex nut than others. Now before I start it, I wanted to see if this was normal or if something is wrong, causing them to tighten down a lot further.
Ok I'll try that. I know there is no bind because I've turned it over a few times already but it doesn't hurt to double check. I'm just curious as to where the polylocks should be when locked down. I've never dealt with them before. Oh well, learning experience time.
Well I finally get the rockers adjusted correctly and everything is good to go. Starts right up, no valvetrain noise, no leaks. I'm just waiting for my valve covers and to get a tune and she will be on the road!
