Roller Rocker Adjustment
Old May 3, 2007 | 06:40 PM
roscoe's Avatar
Default Roller Rocker Adjustment
Anyone have experience adjusting roller rocker arms? I have a 454 with a comp hydraulic roller cam and Harland Sharp (I believe) roller rockers. Thanks!!
Old May 3, 2007 | 10:25 PM
Default RE: Roller Rocker Adjustment
basically, the same as regular rockers, but now you have to tighten the polylock nut without moving the adjustment nut.
Old May 5, 2007 | 12:59 AM
RatMotor's Avatar
ORIGINAL: z28pete
D*mn Polylocks.... Hate Em...Hate Em....but still use Em..
Tighten the nut for lash and then set the lock,only to check with the go-no go method and I'll be D*mned if now they aren't loose. Re-adjust, check, Re-adjust..............check...........[:@]
I'm sure everyone that has adjusted these on a regular basis knows what I'm talking about. Like I said, I'll still use Em.
RM
timmyz28
Sep 8, 2011 06:03 PM
carkivey3
Dec 6, 2009 11:44 AM
built87
Mar 11, 2008 05:01 PM
ScottD
Mar 1, 2008 08:00 PM
heddas68
Sep 21, 2006 11:55 PM
