LT1/LT4 Tech 1993-1997
rockers
Old Jun 16, 2018 | 07:01 AM
6cylrider98's Avatar
Default rockers
Hi All, Playing with a 93 Z28/6spd. Don't want to do a total rebuild but looking for a few more hp, am doing headers and cold air.. question, is updating the springs, seal, and adding 1.6 rockers worth the effort? Will get a tune also when all is said and done. First project Z car got a bit more to do before its road ready, to say the least. Thanks! Any other ideas, 160 tstat will be part of the plan. It has the 3.23 rear /M29 trans..
Old Jun 16, 2018 | 07:32 AM
Y2K's Avatar
Y2K
I think I'd want to ad a cam,lifters and new timing chain to the mix.
Old Jun 16, 2018 | 09:51 AM
Would be ideal but not looking to spend the big$$ has 130k on the clock. haven't driven it yet needs bks and some ft end work , motor is all stock runs on no noises.
Old Jun 16, 2018 | 03:25 PM
Please let me know how you make out with just the rockers, I have pretty much the same car with the same mods and a set of GM 1.6 rockers sitting doing nothing. Don't go crazy on the valve springs. Slightly better then stock would be fine. You don't want to stress those stock lifters.
In theory the stock tune would not be bad because you are increasing the valve opening without changing the dynamics of the CAM duration. If you change the Cam a tune may be needed. Once the opti fails then do the CAM
Old Jun 16, 2018 | 03:29 PM
Yes the great Opti.lol. Was just guessing the extra lift might help a bit to be worth the work to install. Got a bit of work to do and to tag it yet.
Old Jun 17, 2018 | 03:39 AM
leave the 180 thermostat. with the mileage and buget i would not do to much to the engine other than the cai and headers, look into a cat back of your taste. might try lt4 spings with the 1.6 rockers. i would not expect to much gain from it. heads and exhaust are the choke point on the lt1. give solomon at lt1pcmtuning a shoutout and see if he thinks a tune would gain hp worth the bucks.
Old Jun 17, 2018 | 04:15 AM
MKCoconuts's Avatar
I'm with Craby, keep OE temp on the t-stat. The 160* isn't worth squat.
Old Jun 17, 2018 | 05:39 AM
Cool Thanks guys! will look into the tune , it will get the exhaust headers , has a cat back now. Am a GM tech , Saab guy mostly..:-) Turbos are good mmmmkay....... This is my 1st GM toy, it should be ok and a bit of fun too. Thinking if all goes well will get a later Gen 4,say a 2002.. LS does make the hp and easy to get it to go. The 94 I work on, has a very nice LT1 in it ,has had a crap load of stuff done. Strange is it still has the 10 botl and it is a peg leg now..lol. Will get a 9" or a 12 bolt this winter. Thinking of doing some of the mods to mine since it wont see 400hp or much drag time, just going to be a putt around toy... famous last words...
Old Feb 23, 2019 | 03:50 PM
Been awhile , got a bunch of parts and have started the rebuild,ft shocks fixed/replaced, clutch done today got headers for tomorrow, got the rest of the parts I neede dto get it road ready. new opti plugs wires water pump serpt belt and tensnr. found the ac compressor bearing failing, joy... Been a hard winter but is looking up so far. got the lca to rebuild too.both sides.
Blackgloves
Apr 8, 2013 06:20 PM
Masospaghetti
Apr 4, 2010 12:17 PM
murderd96z28
Feb 21, 2010 08:46 PM
BS93Z28
Jul 14, 2009 10:17 AM
baseballer91
Apr 22, 2008 07:13 PM
