1.6 rockers to be installed
Old Apr 1, 2013 | 08:25 PM
Blackgloves's Avatar
Default 1.6 rockers to be installed
Anyone know how hard this is to do? I have the roller rockers already. They have been sitting around. Also, you have had rockers installed what did you pay for labor? I want this to be done in a weekends time. Car is in my garage if you need to know more or want to view it
Old Apr 1, 2013 | 10:05 PM
staff can you move this to general tech please?
Old Apr 1, 2013 | 10:30 PM
done.
you should check to make sure the change has not left the roller contact on the valve out of center. is the cam stock? are the valve springs stock? it will work without changing pushrods or valve springs just not good if everything is not lined up right or if old springs bind or break.
Old Apr 2, 2013 | 05:53 AM
Originally Posted by craby
done.
Car has a cam and valve springs are not stock. Its been balanced and blue printed for 1.6s. Just needs the rockers to be dropped in
Old Apr 2, 2013 | 08:59 AM
heres how to check pushrod length for centering the roller on the valvestem https://camaroforums.com/forum/93-02...29/#post425202
Old Apr 8, 2013 | 06:20 PM
Z28Cam383's Avatar
Default Valve Lash Adjustment
Hey guys, if you are about to adjust the valve lashes, you should do a google search for a magnetic vinyl strip with graphics on it that wraps around your harmonic balancer (temporarily) that shows you exactly where the camshaft lobe heels are at to adjust the valve lashes accurately.
I have one for my Camaro and one for my Corvette and they work great. Just thought I would let you know that something new out there exists for valve lash adjustments. Have fun!
VALHAR
Oct 9, 2014 12:19 PM
xPBxWrEckeD
82-92 V8 Tech
Nov 20, 2007 12:02 AM
DKap22
Mar 14, 2007 07:52 PM
WMadam11
82-92 V8 Tech
Feb 25, 2007 09:20 PM
camarokid1968ss
Apr 23, 2006 12:34 PM
