LT1/LT4 Tech 1993-1997
Replacing Rotors, Calipers, & Pads - Help Wanted
Old Aug 10, 2009 | 02:59 PM
gagger84's Avatar
Default Replacing Rotors, Calipers, & Pads - Help Wanted
First off, I'm new to these forums so I would like to say hi and thanks for the help ahead of time. But without wasting too much time, I would like to get to my question.
I have a work-in-progress '95 Camaro Z28 and am currently working on getting the front brakes, calipers, and pads replaced. The first question I have pertaining to this is what do you recommend I get, drilled, slotted or a combination for the front? I was thinking a combo, but wouldn't mind just slotted. Also, what are some good brands to look at? I found some gripforce F1 drilled/slotted rotors on Ebay that were zinc coated and was quite tempted to purchase those. Any advice would be a ton of help.
Thanks again everyone!
Old Aug 10, 2009 | 03:11 PM
GMDCAMARO's Avatar
SSBC has a nice kit on summitracing. I purchased it for my Camaro and haven't has a single issue.
Old Aug 10, 2009 | 04:57 PM
welcome to the forum. i have had drilled rotors and drilled and slotted rotors and would have to say the drilled and slotted worked better for me. if your doing everything go with a adapter and use some bigger rotors, pads and caliper.
Old Aug 10, 2009 | 06:02 PM
gagger84's Avatar
Craby, what adapter are you mentioning that allows me to use larger rotors/pads/calipers? I don't know a ton about braking systems so I am curious what adapter I should be looking for. Thanks!
Old Aug 10, 2009 | 06:24 PM
traumadog's Avatar
Re: the adapter, it all depends on what you are looking to get. The LT1 Camaro has a single-piston floating-caliper design, where the piston pushes the pads from one side, and the caliper itself slides on guide pins.
Some kits are already designed to mount to the original LT1 guide pin holes. LS1's have slightly different mounts to go with a two-piston floating-caliper setup; you can easily swap those in with new knuckles (some are on eBay).
As for something like the SSBC kit (which is a fixed-caliper setup, IIRC), it should come with an adapter plate already, to make the new caliper mounts line up with the caliper pin holes on the knuckle.
In terms of drilled/slotted - I prefer slotted only. Some cheap drilled rotors are just that - cheap. I've heard stories of them cracking under semi-hard use - something I'd hate to have happen.
Just my $0.02.
Old Aug 10, 2009 | 07:29 PM
^^^there u go. can use a ls setup or a vette c6 (i think) setup or an aftermarket like willwood but at 1500 bucks i dont think thats what ur lookin for. do some research and decide what u want. try a search on this site there are numerous threads on it.
Old Aug 11, 2009 | 10:26 AM
torque_is_good's Avatar
more basic stuff
be sure to change your brake lines since they are probably original and flush the brake fluid.
Me, I got GM loaded calipers for the front on Ebay for $32 each(shipped) and rotors from advanced auto.
rears i did the adv auto parts. But, the car doesn't get raced or auto-crossed
carid
Vendor Special Buys
Mar 18, 2015 07:03 AM
2Z's
Jul 14, 2012 09:44 PM
libertyforall1776
Jul 2, 2012 10:59 PM
BoricuaHec02
Jul 20, 2010 09:24 AM
BAN WS6
Feb 21, 2008 09:36 PM
