LT1/LT4 Tech 1993-1997
Replaced 02 sensor help!
Old 11-07-2011, 08:29 AM
greenmachine96's Avatar
The car pulled a misfire code and was showing it was cylinder 6 only, meaning my firing order is correct. So it probably will save me some trouble in the long run.
Old 11-07-2011, 10:33 AM
what plugs did you use, did you drop any? could just be a bum plug.
Old 11-07-2011, 10:43 AM
mloaks's Avatar
anyone who can get to, and remove, the passenger O2 sensor whenever they like is quite a technician.
Old 11-07-2011, 11:32 AM
I used AC Delco, platinums, i think. '96 has one front and one rear. Might be different from the 95-earlier, The one that I changed was the rear/ post cat..... Anyway it turned out that the wire was bad took me about 25-30 minutes to change the plug and the wire. Never use JEGS brand wires. Car is running great now. Reason i know it wasnt the plug is because i changed that first and tried the jegs wire again and no dice, changed the wire and bingo.
1augapfel
10-02-2013 03:19 PM
dogdog130
10-04-2011 06:57 AM
RodneysPhoto
07-28-2011 07:26 PM
fuhhuayt
05-05-2011 01:04 PM
EagleRex
07-20-2010 03:36 PM
Quick Reply: Replaced 02 sensor help!
