LT1/LT4 Tech 1993-1997
rearend carrier, reluctor ring
Old Apr 20, 2013 | 04:28 PM
sm515's Avatar
Default rearend carrier, reluctor ring
93 camaro z, auto.
lost my posi the end of last year. just one wheel spinning during brake burn. bought a new carrier ( brand name auburn, 100 bucks cheaper than eaton). putting my old ring gear on it with old pinon, new bearings. ive done rearends before, no issues there, first time with 7.5 f body type. problem: i punched that reluctor ring off the wrong direction and broke it. guess it only goes on one way, sort of tapered maybe. question: is it only for the abs? or part of the speedo? abs no problem i wont buy a new one as i took the abs module off years ago. if it affects my speedometer ill have to source one. thx.
Old Apr 20, 2013 | 04:34 PM
Everett#2390's Avatar
Should only be for the ABS.
Speedo comes from the trans tailshaft.
Old Apr 21, 2013 | 07:35 PM
yep for abs. get it tuned out when you get er tuned.
Kubs
Nov 2, 2012 02:57 PM
Kubs
Oct 31, 2012 11:50 AM
the nightmare car
Jun 12, 2011 10:21 PM
Camaro's kick A$$
Dec 24, 2009 07:35 PM
JHL88
Mar 8, 2007 07:58 PM
