rear end noises
Yes I took off the rear end cover and drained oil and replaced it to full because I thought maybe the clutches were sticking and didn't have any metal shavings on the magnet but when finished I still have the clicking almost banging noise
i would think so. ive never used it or had to buy any so im not real sure on that. dealer should know what it is anyways. this is something i found.
1994 THROUGH 1997 CAMARO AND FIREBIRD, 1998 OR OLDER CHEVROLET CORVETTE
USE ONLY GM P/N 12345977 PLUS 4 OUNCES OF GM P/N 1052358 LIMITED SLIP ADDITIVE
1998 AND 1999 CAMARO AND FIREBIRD, 1999 CORVETTE
GM P/N 12378261, SAE 75W-90 SYNTHETIC AXLE LUBRICANT. WITH A COMPLETE DRAIN AND REFILL, 4 OUNCES OF GM P/N 1052358 LIMITED SLIP ADDITIVE
1996 AND OLDER B AND D CARS, AND 1993 AND OLDER CAMARO AND FIREBIRD
USE ONLY GM P/N 1052271 PLUS 4 OUNCES OF GM P/N 1052358 LIMITED SLIP ADDITIVE
Auto zone has what you need, it's a 7 oz. bottle of Posi-Trac additive. Add that in, but you may need to drain some oil if it's at the full point now. Then take it to a parking lot and drive it around in nice easy figure-8's to work it in.
my rear end was doin something very similar after i got the car, turned out that my pinion bearings were wore out and wore grooves in where they sit, so chevy replaced the bearings and put the upgraded ls fluid in the rear and its nice and new now,
but i was getting the same sounds you are describing
Mojo925
70-81 Transmission & Differential
04-10-2013 01:59 PM
