LT1/LT4 Tech 1993-1997
Rear Brake Caliper Issue 95z28
Old May 9, 2009 | 10:24 AM
95greenz28's Avatar
Default Rear Brake Caliper Issue 95z28
Hey guys I just tore apart the rear brakes on my 95 z28. Just curious if anyone knows how to reset these calipers. I tried pushing them in traditionally and no luck. Theres also some sort of attachment it seems on the outside of the piston. Help please?
Old May 9, 2009 | 10:36 AM
attachment should be the e brake. i always push the piston back in before i take the calipers off. stick a big screw driver in there and push it in. careful not to screw up the rotor. have also used a c clamp which is best.
Old May 9, 2009 | 10:48 AM
I use a big c-clamp with an old brake pad in place to compress the piston. But, you want to pop off the brake reservoir cover, or open the bleeder on the caliper first. By compressing the piston, you're pushing brake fluid back into the lines, and it needs to have somewhere to go.
Old May 9, 2009 | 02:53 PM
95greenz28's Avatar
Yaa that was my fault, i was taken back when i pulled the assembly off the rotor, i had never seen a piston look like that. But yea it compressed with ease, sorry guys
camaro kirk
Jan 17, 2010 10:08 PM
eddiebj
Jul 9, 2008 01:16 PM
kaoss_11
Mar 7, 2008 10:44 AM
mike5908
Oct 7, 2007 03:57 PM
gearyr
Apr 18, 2007 03:13 AM
