LT1/LT4 Tech 1993-1997
question about start up
Old Apr 9, 2006 | 08:52 PM
user 7208220's Avatar
Banned
Default question about start up
so...i drove my car home and the engine just stopped without me turning the car off...i checked the battery...its fine....and the alternator is fine...because the battery would be dead...i have sparks coming from the spark plugs i checked...i bought a starter today and installed it...and it still didnt start up...my car turns over it just doesn't want to start...anyone know what else this could be?
Old Apr 9, 2006 | 10:35 PM
mike86rs's Avatar
Default RE: question about start up
what is your fuel pressure like?
Old Apr 10, 2006 | 01:13 AM
Banned
havn't check...how do i check?
Old Apr 10, 2006 | 07:16 PM
Get a fuel injection pressure gauge. Attach it to the test port on the fuel rail. Turn on the ignition, but do not try to start engine. The fuel pump will go into the prime mode and pressurize the system. You may have to do this several times as the pump will shut down in about 15 seconds and may need more time to build up pressure. Fuel pressure should be 40-45 PSI. If nothing happens: the fuel pump fuse may be blown, the fuel pump relay died, fuel pump died. Pressure is low: sick pump, bad fuel pressure regulator, clogged fuel filter. Pressure too high: not likely to happen.
Dadz67
Oct 26, 2011 01:05 PM
nyamped88
Jul 18, 2010 09:20 PM
nyamped88
Jun 25, 2009 04:17 AM
texasnightowl
LS Series Tech
Feb 8, 2009 05:56 PM
bezerker
Jun 28, 2008 05:37 PM
