LT1/LT4 Tech 1993-1997
Question about forged engines
Old Jun 6, 2011 | 10:46 PM
x01660's Avatar
The Mustang Hunter
Default Question about forged engines
So, if I get a forged bottom end (stock displacement) and LE2 heads, could I push, say 15 lbs of boost with a Procharger without grenading my rear end or tranny? (T56)
Because:
Forged kit: $700
LE2 Heads: $1100
Procharger with dyno tune: $5500
Or is that a waste of money?
x01660
Old Jun 6, 2011 | 11:00 PM
NorthernCrew454's Avatar
is this a question about if a forged bottom end will handle it or your transmission?
Old Jun 6, 2011 | 11:20 PM
x01660's Avatar
The Mustang Hunter
Both. thanks
x01660
Old Jun 6, 2011 | 11:32 PM
inanitydefined's Avatar
15 lbs should mean between 500 and 550 crank hp depending on blower efficiency. You're looking at rear end trouble for sure. If you don't shift like a ricer, your tranny will probably hold
I'm inclined to think building na would cost less, especially if you're looking at a whole new rotating assembly. Does the procharger kit come with an intercooler? You're probably looking at another grand or two to do it properly.
Old Jun 7, 2011 | 04:24 AM
timmyz28's Avatar
You will also need a custom grind cam made for forced induction. You will need other things as well, ported intake, injectors, fuel pump, stronger clutch, pressure plate, and flywheel just to name a few things. And I've talked to Lloyd Elliot about something like this already, he recommended LE trick flow heads would be a lot better than LE2 in this setup so that's more money.
T-56s are pretty strong to begin with so like the other guy said, if you're shifting correctly, it should hold. And stock GM 10 bolts are very weak. It will not handle power like that at all, so thats another $2,500 for say a ford 9" or something.
Sorry if I rained on your parade, but I honestly do research and shop around for my build I want to do every day for the past few months. Just trying to show you how much is actually involved in a setup like that.
9434V6
Sep 8, 2011 11:51 AM
jtfeagan33
Jul 26, 2011 10:52 AM
smnimm01
Mar 15, 2008 11:30 PM
sewerrat
Aug 15, 2006 02:34 AM
jleasure24
Feb 22, 2005 11:22 PM
