LT1/LT4 Tech 1993-1997
PVC Line
Old Aug 5, 2011 | 09:21 AM
dstyllz's Avatar
Default PVC Line
I recently found that I have no pressure or suction in the PCV line... Neither from the throttle body nor from the valve cover... What could be wrong and how do I fix it...
Old Aug 5, 2011 | 10:16 AM
grabbem88's Avatar
The way you are checking it. Does the intake port pull any vacuum? Or are you checking the hose?
The extra crankcase vent going to throttle body did you raise the toms to see if it's pulling vacuum? No vacuum means the crancase is building severe pressure and gases and can do severe damage to your motor
Old Aug 5, 2011 | 12:02 PM
i think you are checking the air intake side (passenger side of motor)of the pvc system. the pcv valve is on the driver side of the intake manifold, about half way.
http://shbox.com/1/pcv.jpg
http://shbox.com/1/pcv_pipe.jpg
Old Aug 6, 2011 | 12:24 AM
dstyllz's Avatar
yes, I did check on the passenger side... Should their not be any pressure on that side...
Old Aug 6, 2011 | 01:09 AM
right no pressure on that line. thats where the air comes in that gets sucked into the intake on the other side of the motor. so i guess if you plugged the valve cover side long enough it would creat a suction. well thats if you have the dip stick sealed good and none of the gaskets or seals are shot.
manslaughter299
Jul 24, 2012 03:17 AM
wardee
Jul 6, 2012 10:16 AM
vanquishfist
May 26, 2012 05:46 PM
94z28chevy
Aug 4, 2008 05:05 PM
Deezil13
Sep 12, 2006 12:35 PM
