LT1/LT4 Tech 1993-1997
putting 94 engine harness in 93
Old 06-21-2008, 08:10 PM
jjmann's Avatar
Default putting 94 engine harness in 93
Does anyone know will the 94engine harness mate to the 93 wire harness ie power supply,fuel pump tac ect.I want to up grade to the 94obd1 set up. I have the 94 engine harness/computor and want to pull the 93 ecm and harness out.the fuel and power conection looks the same ecept one wire is a diffrent color then the 94 harness.any help thanks
Old 07-01-2008, 11:26 PM
Saint_Ali's Avatar
Default RE: putting 94 engine harness in 93
why do you want obd1 ? you will have more sensors to deal with, and more tuning when you start to do work on it. it can be done but you will need to get a pcm instead of a ecm, you will need a mass air flow sensor for sure, i dont know what year they started using more o2 sensors, i know 93 only has one
Old 07-03-2008, 02:22 PM
aightball87's Avatar
94 only has the o2s beforeeach cat also
Old 07-30-2008, 07:46 PM
ninety3chevyz's Avatar
i have already meade this change because my 93 computer was bad and could not find one anywere because its a stand alone year with speed density. every thing plugs right in,but you will need mass air sensor,and differnt o2 sensors!other than that its acualy not bad at all to change! and the 93 has two o2 sensors just like the 94,one near each manifold!the only differance is the 93 is a singal wire sensor and the 94 has 4 wires
B_Dubya
01-29-2014 01:12 PM
Brian Z.
70-81 V8 Tech
12-28-2013 02:18 PM
jjmann
06-20-2008 07:02 PM
devinthedude
06-30-2007 06:58 PM
Jon
12-04-2006 07:48 PM
Quick Reply: putting 94 engine harness in 93
