LT1/LT4 Tech 1993-1997
Post headers install question
Old May 16, 2011 | 01:04 AM
xXChipXx's Avatar
Default Post headers install question
So obviously the o2 sensors will go out, but I was wondering if I should bother to replace them. If I get a tune, doesnt it delete them anyway. And besides a code, what else do bad o2 sensors cause
Old May 16, 2011 | 08:55 AM
you do not delete the front o2 sensors only the one/s after the cat if you have one/them. not everyone has the 02's fail after new headers, most do. you will know, car will run rich or lean and probly run rough.
Old May 16, 2011 | 01:09 PM
xXChipXx's Avatar
Thanks craby, I had it mixed up. I was thinking my car wasnt running as smoothe as it should.
Old May 16, 2011 | 01:17 PM
SpecterGT260's Avatar
Ninja Administrator
the O2s wont necessarily go out, they will just register an error (which actually means they are working correctly) because of the new exhaust temps
Old May 16, 2011 | 02:21 PM
xXChipXx's Avatar
so should i replace them?
Old May 16, 2011 | 02:55 PM
Ninja Administrator
no, because it wont fix your problem. You can either deal with the SEL (like i do), get it tuned out, or get rear O2 sims. I had them on my old mustang. worked great and got rid of the light.
Old May 16, 2011 | 04:02 PM
torque_is_good's Avatar
my O2's bought the farm. datalogging was crazy. one moment it was rich and the next it was lean. Every now and then it would backfire. A new set of O2's, and then having Solomon tweak it a bit and it purrrssss like a kitten.....well, more like a growl with the exhaust
FWIW, I only have 2 O2's. I'm still looking for my cat conv but had to install an ORY until I can locate it.
Old May 16, 2011 | 04:43 PM
xXChipXx's Avatar
I feel like im getting different answers.
Old May 16, 2011 | 05:58 PM
ALDL OBD1 OBD cable OBDI OBD2 engine codes
datalog it
Old May 16, 2011 | 06:08 PM
Ninja Administrator
torque, u know that the narrow bands will peg rich and lean over and over again as they bounce around stoich.. you cant datalog narrowbands and get any useful information. going rich and lean isnt an indicator of the o2 going bad, that is just what they do. They know when they are right on, and when they are low or when they are high... but as far as how much high or low they have no idea
