LT1/LT4 Tech 1993-1997
Path to 400?
Old 09-29-2011, 07:55 PM
umm yes and im not up on carb. i know lt headers are not leagal so best you can do is shorties. the cam i have is the largest emission legal cam elliotts has.
Old 09-29-2011, 08:13 PM
Catmaigne's Avatar
Most cams and long tubes aren't going to pass emissions. Unfortunately, those 2 pieces are big performers. You could always look into a smog waiver, but I can't imagine it being cheap in CA (if it exists).
Old 09-29-2011, 08:48 PM
ls1_lyh's Avatar
yea i might get a legal cam and see about headers. i kinda wanted lt headers because of their performance.... i do have a good friend... who can get one of his good friends to pass smog for 250-300. worth it?
Edit: Just curious, how much will cams and the LE2 heads add (hp/torque-wise)?
Old 09-29-2011, 08:59 PM
its going to be tough and expensive to get to 400 in cali. you have to have the cats in the same place as original and im not sure you can use high flow cats. you better do some research on it. im sure theres lots of info on the net for ya.
Old 09-30-2011, 12:13 PM
lt1 xjs's Avatar
Originally Posted by JGuy07
I might be wrong, but when using the 224/230 cam an upgraded stall/converter isn't necessary you can still keep it stock? Granted it wouldn't be the most optimum choice but still would work correct? Even then 226/232 says nothing about changing these on an Fbody, only the Bbody would need a stall upgrade and gears....?
Even stock and bolt-on cars benefit from a good torque converter, I run the Yank SS 3600 myself. A cammed car without a converter is just senseless.
Old 09-30-2011, 12:51 PM
JGuy07's Avatar
Any internals is way off for me at the moment. I was just asking for clarification.
CSBigDawg
04-10-2009 09:57 PM
Quick Reply: Path to 400?
