LT1/LT4 Tech 1993-1997
overheating dont think its headgasket
Old Sep 25, 2011 | 01:57 PM
LeftyLong's Avatar
Unhappy overheating dont think its headgasket
how do i know if cooling fan isnt turning fast enough. when engine is cold remove rad cap and start coolant slowly rises and overflows no bubbles just slow rise dont know if its an air pocket im lost new wat. pump. and stat replaced twice and temp sensor twice and tried two caps no coolant in oil or vice versa. no smoking exhaust tail pipes dry. please help with ideas this is my 5th camaro first lt1 one and ready to blow it up lol.
Old Sep 25, 2011 | 01:58 PM
LeftyLong's Avatar
1996 z28 lt1
Old Sep 25, 2011 | 02:01 PM
LeftyLong's Avatar
the exhaust gaskets and intake apears to have been replaced recently so i am guessing the guy who had the car before me had the same prob and did head gasket but it didnt fix the prob
Old Sep 25, 2011 | 02:07 PM
LeftyLong's Avatar
cooling fans are wired to come on with the ignition but one sqweels some time
Old Sep 25, 2011 | 02:12 PM
LeftyLong's Avatar
car seems to run fine till about 210 temp and coolant starts flowing out of overflow then temp jumps staight to 260 if i rev engine to 2500 or 3000 rpm temp drops for a few sec. this work a few times then temp wont drop only takes about 30 to 45 min to cool down to about 180 or less
Old Sep 25, 2011 | 02:28 PM
JGuy07's Avatar
Did you use the bleeder screws when you refilled the coolant to make sure air pockets are relieved?
Dan Cox
Dec 21, 2011 07:45 PM
RFxCamaro
Sep 23, 2010 10:18 PM
shinwolf14
Jun 4, 2010 03:32 PM
TURBO TEG
82-92 V8 Tech
Apr 27, 2007 05:18 PM
Chappie99
Apr 11, 2007 02:59 AM
