LT1/LT4 Tech 1993-1997
Opti-Spark (ABITS) R&R
Old May 7, 2011 | 02:32 AM
x01660's Avatar
The Mustang Hunter
Default Opti-Spark (ABITS) R&R
Anyone have a write up with pictures on how to do it?
x01660
Old May 7, 2011 | 12:11 PM
lol gona have to use one of them book things.
Old May 7, 2011 | 12:35 PM
Do a google search, plenty of how-to's (and how not to's) out there in internet land. If you're also going to replace the water pump shaft timing cover seal, speak up. There's a trick to it, and I posted a how to on that.
Old May 7, 2011 | 04:38 PM
u will need to pull the belt, air cleaner unit including the tube that goes down by the radiator, the fan shrowd, water pump and the harmonic balancer to get the opti out. need a ballance puller. keep track of the arrow on the balancer, if #1 is at top dead center it should be pointing up.
Old May 7, 2011 | 04:41 PM
x01660's Avatar
The Mustang Hunter
Sounds good. Looks like I'm gonna have to do a complete writeup with pics when I get to it. Thanks, Craby!!
x01660
P.S. I LOVE your rims!! What type are they?
Old May 7, 2011 | 07:42 PM
Two things...you don't/shouldn't need a puller, the lower pulley isn't a press fit. It will be tight from years of rust and gunk, but you can rap it off from underneath the car with a hammer and block of wood, working from side to side. Soak it well with PB Blaster the day before you start the project. Also, there are clocking marks (arrow to raised notch) for lining the pulley back up to the hub.
Old May 7, 2011 | 08:28 PM
Grandpaswagon's Avatar
There are a couple of good writeups online complete with pics. I can't remember the site, but I found one that showed the entire process and had lots of notes about what to watch for and little tips (such as the harmonic balancer removal). I followed it step by step and got mine done without issue.
It was a lot better than a Haynes manual on how to do it.
As Camaro69 said, try a google search and you will find one or two that fit the bill.
No sense in re-inventing the wheel.
Old May 7, 2011 | 11:51 PM
I had this one bookmarked, it's a pretty good write-up: Opti-Spark Options
hyozanryu
Jun 15, 2013 06:43 PM
bd92rs
Sep 26, 2011 11:17 AM
camarorz28
Jul 25, 2008 10:56 AM
nash211
Jan 15, 2007 05:42 PM
ufnwish
Oct 8, 2006 06:38 PM
