LT1/LT4 Tech 1993-1997
opti finally gone?
Old Nov 6, 2010 | 06:44 PM
It's the equivalent of having an old school engine with a conventional distributor and never giving it a tune-up for 100k+ miles. Even that engine will be running crappy, if at all, by then.
Installing the water pump seal is tricky (if you did replace it, hopefully). There's a right and wrong way of doing it.
Old Nov 6, 2010 | 07:02 PM
imcdowel's Avatar
i did it right i read all your tricks and the guy helping knows lt1's like the back of his hand. also the many threads on here helped a ton. reading for an hour saves about 4 hours of work.
Old Nov 6, 2010 | 09:48 PM
If it is pinging, you should take a look at the Knock Sensor and its wiring. The PCM looks at the KS for knock signals and retards the spark until it stops.
Old Nov 13, 2010 | 10:55 AM
Turbolag86's Avatar
Hey everyone....I was hoping to chime in on this Opti discussion.
I am having a similar issue I believe.
Today I was driving my Camaro ( 96 Z28) and I was sitting at a stop light...and all of a sudden the RPM dropped to about 600 then jumped back up to 1100 and idled back down to 900, which is where it normally idles at.
Then I took off from the stop light, and shifting into second, then while accelerating in 2nd i got to around 1500 RPM then the engine felt like it was hesitating, and all of a sudden it jerked and the power was back, then it did it again in 3rd gear at about 1500 RPM, this time I push the throttle down more and it didnt do anything, then it jerked again and the power was back. So I turned around and got my truck....Haha
It also has a funny smell after I turn it off...Kinda of like a flooded smell. Does this sound like the Opti ?
I noticed it had been losing hesitating at 1500 for a couple weeks, but today it was the worst its been so far.
Old Nov 13, 2010 | 01:39 PM
torque_is_good's Avatar
start a new thread please
pssstttt- but it sounds like O2 sensors to me and the computer can't compensate
Old Nov 18, 2010 | 03:03 PM
ChandlerMotorsports's Avatar
Former Sponsor
Pull codes first. Also, do your symptoms change after 10-15 minutes? Also, with richness I would also agree on the O2s, ESPECIALLY if it runs good cold and then it almost switches into crap mode.
VALHAR
Sep 13, 2012 10:36 AM
sgtdupree
Jul 23, 2011 07:42 PM
hoursetraitor
Mar 22, 2011 03:35 AM
94zguy
Dec 23, 2010 02:42 PM
sbcman25
Jan 29, 2010 02:01 PM
