LT1/LT4 Tech 1993-1997
Is this the oil pressure switch?
Old Oct 19, 2006 | 02:37 AM
sewerrat's Avatar
Default Is this the oil pressure switch?
Dang it, what is this that I just broke? I was trying to remove my trans to do a rear main seal leak and I accidently broke this. Also can anyone tell me how to get to the upper trans to engine bolt on the passenger side? Do you need a 3' extension? My vehicle is a 94 lt4 4l60e trans
[IMG]local://upfiles/1013/6E3E11390C5445548F78276D281C2301.jpg[/IMG]
Old Oct 19, 2006 | 09:30 PM
Default RE: Is this the oil pressure switch?
Yes, that is the oil pressure sensor switch. This item also has contacts that feed power to the fuel pump. Official name "Sensor Assembly, Fuel Pump and Engine Oil Pressure Indicator Switch".
Take the tranny Crossmember out, this should allow the engine to drop enough to get the bolt out.
Old Oct 19, 2006 | 10:46 PM
shnormo's Avatar
Yep. Just unscrew the old one out and put the new one in.
jdrpco
Jan 2, 2014 02:11 PM
wayne242
Oct 27, 2012 06:23 PM
BasicConcepts
Dec 9, 2011 11:31 PM
greg w
Dec 22, 2009 03:48 AM
TheWanderer
Jul 31, 2008 01:17 PM
