LT1/LT4 Tech 1993-1997
Oil pressure?
Old Jun 18, 2014 | 11:37 PM
jeffchairs's Avatar
Default Oil pressure?
At an idle what kind of oil pressure are you guys running?
Old Jun 18, 2014 | 11:56 PM
Depends on engine temperature. My LT1 idles between 60-70 psi on a cold engine, around 40 psi if the engine is around 190. At 200 degrees it's around 30. If the engine gets really hot, it might go down to 20. This is with 106k miles on the clock.
Old Jun 19, 2014 | 05:16 PM
MKCoconuts's Avatar
I'm at 60-65 psi when cold. Operating temp I'm around 45-50, depending on my rpms. Lowest it's gone since new oil is 35 psi and that was with the temp gauge 3/4 of the way up. 125k miles.
Old Jun 20, 2014 | 09:21 AM
cold60/40warm
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
