LT1/LT4 Tech 1993-1997
Vss 93 z
Old Jun 23, 2014 | 09:40 PM
sm515's Avatar
Default Vss 93 z
Unrelated to my other thread I started about rear end gears, tail shaft speedo gears ect,....My speedo stopped working. I have a volt meter, what voltage should I expect on the two wires going to the VSS? 93 Z auto, Thanks,
Old Jun 24, 2014 | 10:41 AM
look here and see if it helps. found in the how to and faq sticky in the 4th gen general section. https://camaroforums.com/forum/lt1-l...44/#post655676
Old Jun 24, 2014 | 11:23 AM
sm515's Avatar
Nice work, thank you.
Old Jun 24, 2014 | 04:11 PM
sm515's Avatar
after chasing around voltage that just didn't seem right to me at the VSS pigtail it turned out to be the VSS dowel pin was sheared off inside the tail. I had just replaced the drive gear back there, you would think I would look there first. Anyways I need a new VSS...that is specific to my 93? or is there other years that would work? Thanks.
Old Jun 24, 2014 | 08:10 PM
they show a bunch of them. yes you have gear driven. have a look at rock auto. match yours up with picture on there page. i believe its a 213197
