oil pressure
Fukky warmed up engine. Minimum of 5 PSI @ idle, 15 PSI @ 1000 RPM., increasing 10 PSI per 1000 RPM. Generally, low oil presssure is the result of worn engine bearings, bad oil filter, internal leaks, or clogged oil passages. The oil pump is pretty reliable and is the best lubricated part of the engine. Rather than wearing out is usually breaks.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
