LT1/LT4 Tech 1993-1997
oil pan gasket help
Old Aug 7, 2009 | 09:00 PM
rondavis's Avatar
Default oil pan gasket help
so i was having trouble pulling out my oil pan out and i could not get it out past the the trans with motor mount thru bolts out and the motor pulled up as far as it goes the only thing i didnt do is un bolt the headers should i have or is this not the problem i have a 95 Z28 M6 so any help is welcome cuz i have to pull the pan out so i can check it to make sure it is not messed up and so i can clean it
Old Aug 7, 2009 | 09:34 PM
u need to turn the motor over so the counterweights on the crank shaft are in a position so not to get in the way. i assume u got the starter, dipstick, oil level sensor out and all the other crap out of the way.,
Old Aug 7, 2009 | 09:40 PM
its a tight fit but itll come out. been there done that. i did have to unbolt the y pipe and let it down a little but do u have one.
Old Aug 7, 2009 | 09:45 PM
Saint_Ali's Avatar
you may have to drop the trans a little
Old Aug 7, 2009 | 09:50 PM
rondavis's Avatar
k thanks i thought that might be the case
Old Aug 7, 2009 | 09:53 PM
i thought about that but it would have let the back of the motor down and the pan has to come out the stearn side. i was stuck to until i read in the book about turning the motor over.
mike in ohio
Mar 6, 2011 09:21 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
ryden
Mar 14, 2010 05:30 PM
TEXASMAN1
Oct 1, 2008 12:53 PM
dcanada53
Mar 5, 2008 06:01 PM
