LT1/LT4 Tech 1993-1997
Odd idle
Old Jan 19, 2012 | 12:15 PM
numskull223's Avatar
Default Odd idle
I thought I had this fixed, but Ive been running around my house with the cut outs open for a while. I dont drive it far since no tag on it. But today I drove it and ran great, idled good. So I pulled in and closed the cut outs. Soon as i cranked it with them closed, I noticed the idlel was at 1500, them after about 10 sec it idled down till the engine lite come on and didnt want to idle. I revd it alittle, engine lite went off and repeat the process...lol. Does not do that with the cutouts open??? Since I cant pull the codes, what is anybodies idea about this.
Old Jan 19, 2012 | 01:25 PM
RFxCamaro's Avatar
Where are the cutouts? Scan the code and see what it says.
Old Jan 19, 2012 | 03:28 PM
Cutouts are on the header after the O2 sensor. I dont have a scanner and with not tag for the street...it makes it hard...lol runs fine with cutout open tho.
Old Jan 19, 2012 | 03:55 PM
Ok. Im gonna bite the bullet and buy a code reader. My 95 has OBD2 plug....but all these scanners say 96 and up......will these work?
Old Jan 19, 2012 | 06:36 PM
Your 95 is OBDI with an OBDII connector. A plain code reader won't work. You will need a real OBDI scanner with an OBDII cable, or a Scanner than can do both OBDI and OBDII cars. Another option would be OBDI & OBDII scanner software and appropriate cables for a PC.
Being that it runs better with open exhaust you may want to check for the possibility of a clogged exhaust (cat, muffler, pinched exhaust pipe).
Old Jan 19, 2012 | 07:06 PM
you are changing the exhaust flow and not giving the computer time to adjust. try unhooking the battery for a while to clear the computer, shut the cutout and start it and run for a time, see if it clears. is it tuned and what mods have been done?
Old Jan 19, 2012 | 08:32 PM
Catmaigne's Avatar
Old Jan 19, 2012 | 08:38 PM
Ill check it out craby, i have a master power disconnect on the back bumper...its off.
i have all the cables and software for the car to check it out but i cant get it to work on my dinosaur laptop....lol
Old Jan 19, 2012 | 08:40 PM
Oh yeah. Yes its tuned and all the mods are in my sig here. I may need to connect that ground wire i found coming out of the wiring harness at the back of the motor...lol
Old Jan 20, 2012 | 12:22 PM
Well...i noticed something today. I had the batt disconnected and cranked it this morning. Ran different. But i noticed it is running real rich on the diver side, smoking out of the driver side and i smell gas...now i smell like gas...lol. Injectors?
